RV042G keeps freezing
I have a Cisco rv042g small business router with static IP and a regular use for about 200 people. The router keeps freezing and the only thing that seems to help is a reset in GUI. Any helpful tips or tricks to do? The location of the system is to remote and not convenient to keep driving for just a reset. All of the components is Cisco of course.
the first thing to check with these small business routers is usually the firmware, make sure you have the latest release (v4.2.3.08) installed...
Check page 77 of the attached user guide for instructions on how to upgrade the firmware.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv0xx/administration/guide/rv0xx_AG.pdf
The router fw is up to date
