RV320 DCHP issue
steenbroberg
Hi Cisco support community
We have some DCHP issues with RV320. Some client do not received DHCP information (IP, Gateway etc) from RV320 when requested.
Its only a few clients in the network. If we set IP adresses manually on the effected client, the client is up and runing.
Do any have some issues like this.
Can you recommed a sniffing tool to see the communication between the client and RV320
pwwiddicombe
Level 4
Level 4
Do you know how many addresses are in the DHCP pool; and is it possible all DHCP addresses are either in use or reserved?
Thank you for feedback
Have check.This is not an issue.
