RV325 WAN IP Range/DMZ setup
Marc Angelo
I have an IP range say 32.32.32.32/29
A DMZ 10.11.11.0/24
A LAN 10.10.10.0/24
...33 is assigned to the gateway router
...34 should be for the RV325 which would be the LAN gateway (NATting LAN traffic)
How do I configure the RV325 so that the other addresses (...35 to ...38) to point at hosts in the DMZ?
Thanks in advance,
MPA
Hello
If you DMZ going to be natted also and that device supports it them Port Forwarding could be used?
res
Paul
Kind Regards
Paul
Yes i see what you're saying...
but I think that that maybe half the answer. I can port forward yes but I need the RV325 to port forward for a different address.
I was imagining that I defined the gateway to the other addresses (...35 to ...38) to be ...34 (the address of the RV325) and then "somehow" the RV325 routed/forwarded that traffic to hosts in the DMZ.
