RV325
pierre.r.scott
Community Member
I want to increase the maximum available number of IP addresses that DHCP can allocate, but when I try to go beyond .149 it comes up with an error saying that  "PPTP IP and SSL IP" range overlap.   We do not need either of these, but I cannot find where I can disable them so that I can extend the range
Thanks for your help
The Range overlap means same range of IP subnet you had assigned on another interface of the router. So first of all check all other interfaces/VPN configuration Pool for any overlapping the subnet mask.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
