RV340 Access LAN IP from network attached to WAN port
JohnRuse
I have a RV340 router with a local LAN range of 192.168.10.xx/24, the WAN port is connect to another network with a static IP of 10.79.152.100. I need to be able to route from several IPs in the 10.79.152.xx range to a specific IP in the private LAN, an IP of 192.168.10.52.
I have tried Port forwarding, Access Rule and Static NAT but nothing works, clearly I am doing something wrong.
Any help will be much appreciated.
balaji.bandi
6 Replies 6
balaji.bandi
Follow below guide :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5818-configure-port-forwarding-port-triggering-nat-on-rv34x-serie.html
Please pos the screenshot what is configured. ?
BB
This is now resolved. I most likely had it correct at one point yesterday and did not realise. Resolve was setting all traffic to port forward to internal processor. Everything is now working.
Thanks all for your replies.
--> I have a RV340 router with a local LAN range of 192.168.10.xx/24, the WAN port is connect to another network with a static IP of 10.79.152.100.
Post a diagram of your topology. It is unclear how that 'other' network is connected to your RV340. I assume the 'other' network is NOT the Internet ?
Hello ,
Diagram attached.
The other network is not the internet but a VLAN from the upstream router.
John
Hello
Do you have admin control of rtr 10.79.152.1, As what you need to look at is policy base routing from 10.79.152.1 for those specific hosts towards 192.168.10.0/24 lan - However your diagram dosent seem correct,10.79.152.1 rtr has two interfaces into what looks like the same network can you confirm please?
Kind Regards
Paul
Unfortunately I do not have access to router 10.79.152.1. This router has one port connected to the WAN port only on the RV340 with the IP address of 10.79.152.100 assigned to that port. Everything behind the RV340 has no means of connecting to the 10.79.152.1 network other than through the WAN port on NAT. This part works fine as desired. I just need a controller that is on the 10.79.152.1 network to traverse the RV340 to a processor on the internal LAN of the RV340.
John
