Same statics routes on Cisco 891
RashhadMiah91
Can someone please help me? I don't seem to know why this router has two default routes in the running config. Please see below
ro-1.gbr.amsterdam#show running-config | i ip route
ip route 0.0.0.0 0.0.0.0 192.168.1.254 254
ip route 10.74.254.0 255.255.255.0 10.10.10.2 name
ip route 10.74.254.77 255.255.255.255 10.10.10.2
ip route 29.8.15.8 255.255.255.255 10.10.10.2
two default routes which are exactly the same don't make any sense to be honest. Since they both have an administrative distance of 254, they might have been used as a backup for a dynamic routing protocol at some point.
Do you have just that one 891 router in your network ?
Hi Gerog,
Yep just the single 891 in the network, I have no idea why the running config is displaying the two routes. I would have assumed that the router would have overwritten the old one instead of registering both
Hello
Try deleting and re-adding - obviously if your remote admin making sure you dont permanently lose connection doing this
Kind Regards
Paul
