same subnet in different vrf on the same router
brux84
Hi ,
i would like to configure on a pair of Cisco 7609 PE routers two L3 SVI interfaces on the same subnet but in different vrf; Is it possible to create such architecture (see attachment)?
2 Accepted Solutions
Jon Marshall
Yes that should work fine.
Jon
Seb Rupik
Hi there,
As @Jon Marshall points out the topology would work. The layer 3 configuration would look something like:
! PE-A
ip vrf VRF-X
ip vrf VRF-Y
int vlan 10
  ip vrf forwarding VRF-X
  ip address 10.10.10.2 255.255.255.248
  standby 1 ip 10.10.10.1
  standby 1 priority 110
int vlan 20
  ip vrf forwarding VRF-Y
  standby 2 ip 10.10.10.1
  standby 2 priority 100
! PE-B
ip vrf VRF-X
ip vrf VRF-Y
int vlan 10
  ip address 10.10.10.3 255.255.255.248
  standby 1 priority 100
int vlan 20
  standby 2 priority 110
cheers,
Seb.
Jon Marshall
Jon
Seb Rupik
Hi there,
! PE-A
ip vrf VRF-X
ip vrf VRF-Y
int vlan 10
int vlan 20
! PE-B
ip vrf VRF-X
ip vrf VRF-Y
int vlan 10
int vlan 20
cheers,
Seb.
