sami module unknown
teymur azimov
Hi Dears. when i upgrade the supervisor image after this error occur at my cisco router. the sami module status is unknown. what is the problem?
is a problem sami module image?? please help me.
pdsn1#sh mod
Mod Ports Card Type Model Serial No.
1 7 SAMI Module WS-SVC-SAMI-BB-K9 SAL15056HSV
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL14480S9Q
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE SAL1538QE8N
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE SAL1538QHZB
Mod MAC addresses Hw Fw Sw Status
1 f866.f2b1.c700 to f866.f2b1.c707 2.5 Unknown Unknown Other
2 c471.fe47.1ed8 to c471.fe47.1f07 4.1 12.2(18r)S1 12.2(33)SRE4 Ok
5 c89c.1dfb.b370 to c89c.1dfb.b373 5.12 12.2(33r)SRD 12.2(33)SRE4 Ok
6 c89c.1dfb.b3b8 to c89c.1dfb.b3bb 5.12 12.2(33r)SRD 12.2(33)SRE4 Ok
Mod Sub-Module Model Serial Hw Status
1 SAMI Daughterboard 1 SAMI-DC-BB SAL15056FW0 1.2 Other
1 SAMI Daughterboard 2 SAMI-DC-BB SAL15056FVG 1.2 Other
2 Distributed Forwarding Card WS-F6700-DFC3C SAL1532LU97 1.4 Ok
5 Policy Feature Card 3 7600-PFC3C SAL1538QLPL 1.2 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 SAL1538QM24 1.6 Ok
6 Policy Feature Card 3 7600-PFC3C SAL1538QLQB 1.2 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 SAL1538Q9LR 1.6 Ok
Mod Online Diag Status
1 Unknown
2 Pass
5 Pass
6 Pass
14 Replies 14
Ivan Shirshin
Could you attach the "show log" file to the case including the time the module was booting up?
Also, what was the upgrade about  - HW/SW? and what was the old version?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Ivan. i want to know the supervisor image can be affect sami module image?
SAMI is supported since SRC and is compatible with SRE, so it should affect the module.
Kind Regards,
Ivan
Kind Regards,
Ivan
i have one question. is it possible i put sami module to other slot??
You can use any slot for SAMI, except for the supervisor slots 5 and 6. It can be helpful to test SAMI on other slot to see if the error follows the card or slot (e.g. if the card or chassis have HW failure). It is difficult to say anything on the reason the SAMI is down without the logs, though. I can check on those if you share the logs from the time of the issue or the logs from the time you insert SAMI on other slot (during its boot).
Note that SAMI does not support hot swapping. Do not remove the SAMI from the chassis until the module has shut down  completely and the status LED is orange or off. If you remove the SAMI  from the chassis before it completely shuts down, you can damage the  SAMI.
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan.
i put it other slot (slot 3). led is red and when write show module it show me this:
pdsn1# show module
3 7 SAMI Module WS-SVC-SAMI-BB-K9 SAL15056HSV
3 f866.f2b1.c700 to f866.f2b1.c707 2.5 Unknown Unknown Other
3 SAMI Daughterboard 1 SAMI-DC-BB SAL15056FW0 1.2 Other
3 SAMI Daughterboard 2 SAMI-DC-BB SAL15056FVG 1.2 Other
2 Pass
3 Unknown
5 Pass
pdsn1#hw-module module 3 re
pdsn1#hw-module module 3 reset ?
Proceed with reload of module?[confirm]
% reset issued for module 3
pdsn1#
*Jun 25 10:28:28.355: %C7600_PWR-SP-4-DISABLED: power to module in slot 3 set off (Reset)
*Jun 25 10:28:28.359: %CHKPT-SP-4-GET_HUGE_BUF: Client 61 buffer requested (size = 4056) is too large
*Jun 25 10:28:43.359: %CHKPT-SP-4-GET_HUGE_BUF: Client 61 buffer requested (size = 4056) is too large
pdsn1#
the led is indicate red mean
Indicates one of the following conditions:
The boot code failed to run
The SAMI is released from reset by the supervisor engine and is booting
pdsn1#dir sup-bootdisk:
Directory of sup-bootdisk:/
    1  -rw-   147802532  Sep 29 2011 18:40:54 +00:00  c7600rsp72043-advipservicesk9-mz.122-33.SRE4.bin
    2  -rw-    33554432  May 30 2012 06:18:38 +00:00  sea_log.dat
    3  -rw-    41584640  Sep 29 2011 19:07:10 +00:00  c7600-fpd-pkg.122-33.SRE4.pkg
pdsn1#show disk0:
-#- --length-- -----date/time------ path
1     52842487 Jun 22 2012 10:10:56 +00:00 c7svcsami-c6ik9s-mz.124-22.XR11.bin
459235328 bytes available (52846592 bytes used)
pdsn1#show ver
pdsn1#show version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 30-May-11 04:36 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE4, RELEASE SOFTWARE (fc2)
pdsn1 uptime is 52 minutes
Uptime for this control processor is 53 minutes
System returned to ROM by  power cycle (SP by power on)
System image file is "bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRE4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 917504K/65536K bytes of memory.
Processor board ID FOX1525GBU8
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
3 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
7 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
pdsn1#dir bootdisk:
Directory of bootdisk:/
    1  -rw-          42  Sep 27 2011 16:30:14 +00:00  SLOT1SAMIC3.cfg
    2  -rw-          42  Sep 27 2011 16:30:16 +00:00  SLOT1SAMIC4.cfg
    3  -rw-          42  Sep 27 2011 16:30:16 +00:00  SLOT1SAMIC5.cfg
    4  -rw-          42  Sep 27 2011 16:30:16 +00:00  SLOT1SAMIC6.cfg
    5  -rw-          42  Sep 27 2011 16:30:16 +00:00  SLOT1SAMIC7.cfg
    6  -rw-          42  Sep 27 2011 16:30:16 +00:00  SLOT1SAMIC8.cfg
    7  -rw-          42  Jun 22 2012 11:31:20 +00:00  SLOT3SAMIC3.cfg
    8  -rw-          42  Jun 22 2012 11:31:22 +00:00  SLOT3SAMIC4.cfg
    9  -rw-          42  Jun 22 2012 11:31:22 +00:00  SLOT3SAMIC5.cfg
   10  -rw-          42  Jun 22 2012 11:31:24 +00:00  SLOT3SAMIC6.cfg
   11  -rw-          42  Jun 22 2012 11:31:24 +00:00  SLOT3SAMIC7.cfg
   12  -rw-          42  Jun 22 2012 11:31:26 +00:00  SLOT3SAMIC8.cfg
518791168 bytes total (518692864 bytes free)
Ivan please help me to solve this issue.
thanks.
Hi Teymur,
Were you able to collect the "sh log" I have requested earlier? Please attach it to the thread, as for now the only symptoms we have is that card is not going out of the boot sequence on 2 different slots - could be HW issue but coujld also be a problem with boot configuration itself.
You may also want to try to boot it with old IOS image again (downgrade ISO version temporarily) to check if there is some unknown compatibility issue that we need to look deeper into.
Kind Regards,
Ivan
Kind Regards,
Ivan
ok tomorrow i will sent you logs. is it possible this problem hardware issue?  or how i test to known it is module boot problem? which diagnostics can i do?
what do think is  this config help  to me? i do this for sami module and it is image(c7svcsami-c6ik9s-mz.124-22.XR11.bin)
SUP# hw-module module 4 boot config-register
slot4/Admin(config)# config-register 1
slot4/Admin(config)# boot system image: c76-sbck9-mzg.3.0.1_AS31_0.bin
slot4/Admin(config)# no boot system image: c76-sbck9-mzg.3.0.1_AS30_2.bin
slot4/Admin(config)# do write mem all
slot4/Admin(config)# end
Sup(config)# boot device module 4 disk0: c76-sbck9-mzg.3.0.1_AS30_2.bin
Sup(config)# end
Sup# hw-module module 4 boot config-register
Sup# hw-module module 4 reset
