saving configuration issue with cisco ISR4331 with LTE Module
khalidalminyawi
hi , can anyone help in this ,
i have cisco 4331 router with LTE Module after finishing my configuration and executing copy run config start up config command even write memory command in order to save my configuration but unfortunately after reloading the router i can’t found configuration in show running config but I can find all my configuration in show configuration command result,  so every time I power on router i need to execute copy start up config running config to bring my configuration back : below is show running config, show configuration and version.
Router#show running-config
Building configuration...
Current configuration : 1700 bytes
! Last configuration change at 16:31:39 UTC Thu Sep 24 2020
version 16.8
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4331/K9 sn FLM23460ANG
no license smart enable
diagnostic bootup level minimal
redundancy
mode none
controller Cellular 0/1/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface Cellular0/1/0
no ip address
shutdown
interface Cellular0/1/1
no ip address
shutdown
interface Ethernet-Internal1/0/0
no negotiation auto
interface Ethernet-Internal1/0/1
no negotiation auto
switchport mode trunk
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
no ip http server
ip http secure-server
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Router#
Router#show configuration
Using 2109 out of 33554432 bytes
! Last configuration change at 16:21:33 UTC Thu Sep 24 2020
version 16.8
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
redundancy
mode none
no lte firmware auto-sim
interface Loopback0
ip address 1.1.1.1 255.255.255.255
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
ip address negotiated
dialer in-band
dialer idle-timeout 0
dialer enable-timeout 2
dialer watch-group 1
dialer-group 1
pulse-time 1
no ip address
no negotiation auto
no negotiation auto
no ip address
negotiation auto
no ip http server
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0
access-list 1 permit any
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip list 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Router#
Router#show version
Cisco IOS XE Software, Version 16.08.01
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.8.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 27-Mar-18 13:43 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 6 minutes
Uptime for this control processor is 9 minutes
System returned to ROM by Reload Command
System image file is "bootflash:isr4300-universalk9_npe.16.08.01.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9_npe None None None
securityk9_npe
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1731209K/6147K bytes of memory.
Processor board ID FLM240110B1
3 Gigabit Ethernet interfaces
2 Cellular interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Configuration register is 0x2142
Router#
balaji.bandi
change the config registry  this is the issue "Configuration register is 0x2142"
Router(config)#config
Router(config)#config-register 0x2102
Router(config)#end
here is the reference
https://www.cisco.com/c/en/us/support/docs/routers/2500-series-routers/6201-lose-config-6201.html
BB
balaji.bandi
Router(config)#end
BB
many thanks, now it's work
