SCP Entire Contents of FLASH on Cisco Device
jpanzica747
I would like to make backups of my cisco devices using SCP from a linux filesystem.  I am running the following command:
scp username@192.168.1.1:flash/ /dir/to/backup
...where 192.168.1.1 is the cisco device's IP.
I get the following response to the command:
scp: flash/: No such file or directory
What is the correct way to reference the entire flash on the cisco device with the SCP command?
6 Replies 6
typically, flash is followed by a ":", so try:
scp username@192.168.1.1:flash: /dir/to/backup
No, that did not work.
try a double backslash:
scp username@192.168.1.1:flash:// /dir/to/backup
Some routers use flash0, flash1, etc., make sure you are referencing the correct file system
I get the following error:
error: unexpected filename:
Hi Georg,
I tried the double slashes and it is not working.  I would think this is something commonly done to backup flash contents and cannot figure out correct syntax to do it.  Am I going about trying to backup flash contents with SCP and should be using another protocol?
jpanzica747
Anyone have any idea on how to make a recursive copy of the flash through SCP?  This seems like something that people would commonly do but cannot find any answers or solutions on how to do this.
