SDM Configuration
Srinivas N
Hi Friends...
I have a cisco catalyst 2960 switch and i updated ios v-12.2 to 15.0.
my switch is running with vlans..
in other words i installed cisco SDM v.2.5.
but i am unable to run the sdm... plz tell me any configuration is required in both (switch and system)
Thanks & Regards,
Srinivas.
Latchum Naidu
Hi Srinivas,
See the below link will help you...
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swsdm.html#wp1140528
Please rate the helpfull posts.
Naidu.
cadet alain
SDM is for routers not switches. You can use CNA  as  a GUI for switches.
http://www.cisco.com/en/US/products/ps5931/index.html
Regards.
Alain
