SDSL bonding on C888-k9
Dirk Dietz
Hi all,
i am trying to setup two SDSL lines provided from our partner in Belgian on a C888-K9.
Here my startup config
controller SHDSL 0
 dsl-group auto
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
mtu 1460
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no peer default ip address
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxx
no cdp enable
The lines are connected via a Cisco cable so that wire 0 and wire 2 are in use. The router is detecting a line and dials in, access granted.
Problem: Only one single line comes up all the time.
Output when controller is using 2-wire:
show controllers shdSL 0
Controller SHDSL 0 is UP
  Hardware is 4SHDSL-EA
  Capabilities: EFM: 2-wire, EFM-Bond, Annex A, B, F & G
                ATM: 2-wire, Mpair, Annex A, B, F & G
  CPE termination
  cdb=0xF6D78C8, plugin=0x18CDD64, ds=0x19D49D8 base=0xDF500000
  Linux Firmware version: SHDSL_EA_FW_20140721231603
  Vendor: Infineon, Chipset: SOCRATES-4e
  PHY Source: System
  IDC Firmware version: 1.8.1.0
  DFE Firmware version: 1.1-1.8.1__001
  Group info:
        Type: ATM 2-wire status: Up
         Ethernet Interface: Ethernet0, hwidb: 0xF6D82E8
         ATM Interface: ATM0, hwidb: 0xF7477BC
         Currently active interface: ATM
        Configured/active num links: 1/1, bit map: 0x4/0x4
        Line termination: CPE, Annex: B
        PMMS disabled,Line coding: 16-TCPAM
        Configured/actual rate: AUTO/2048 kbps
        Loopback type: None
        Dying Gasp: Present
        SHDSL wire-pair (2) is in DSL UP state
                LOSWS Defect alarm: none
                SNR Margin alarm: none
                Loop Attenuation alarm: none
                Termination: CPE, Line mode: 2-wire, Annex: B
                Modem status: UP_DATA_MODE,Condition: GHS_TRANSFER_
Output when controller is set to use 4-wire
  CPE termination
  PHY Source: System
  Group info:
        Configured/active num links: 1/1, bit map: 0x1/0x1
        Loopback type: None
        Dying Gasp: Present
        SHDSL wire-pair (0) is in DSL UP state
I have played arround but never got two lines up and running. What did i to solve the issue?
- reconnecting them to wire 0 and wire 1.
- set dsl-group from auto to use pairs 0-1 or 0-3
- played around with handshake
Strange thing is, i have another C888-K9 in Switzerland which runs in EFM mode where 3 lines are up and running.
Does anyone has an idea why in atm mode only one line comes up?
IOS i am using: c800-universalk9-mz.SPA.154-3.M1.bin and newer ones on this tree without success.
Hope someone has an idea.
Many thanks
Dirk
Dirk,
I think your provider has to support bonding. Who is the ISP ?
Hi Georg,
it's EDPnet.
They told me they use a 1841 with a HWIC where do dsl-Groups to configure different pairs.
Many thanks
Dirk Dietz
Hello Dirk,
I have been trying to find a sample config for EDPnet.
Try the following settings:
controller SHDSL 0
 mode atm
 dsl-group 0 pairs 0-1 m-pair
  shdsl rate auto
