Secondary IP address in the same subnet and EIGRP
prakkdangc
I have the following config on an L3 switch:
interface Vlan2
ip address 10.10.2.141 255.255.255.224 secondary
ip address 10.10.2.129 255.255.255.224
no ip redirects
EIGRP is running on this switch, and then redistributes in BGP on the edge router. Accessing the secondary IP address from outside the network sometimes fails. I cannot see why.
Any ideas?
Dave
johnspaulding
How many times a day does it fail? Have you noticed any routing changes? Are you at a remote location and do the route get redistributed into an MPLS cloud? thanks
Thanks John .. turned out to be an IP conflict.
Dave
Thanks for the quick response!
no problem....Dont you hate that :)
