Secondary IP Addresses
F Martinez
What are the reasons why we would use secondary IP addresses?
Thank you in advance!
One of the reasons I can think is to be used as a workaround when you have no more Layer 3 ports available in your Router and you have a need to configure a new subnet.
The secondary IP address can be used as a default gateway for the new subnet.
However, the negative outcome is that you will have 2 different subnets on the same broadcast domain.
It is always a best practice to have 1 subnet per broadcast domain.
Let's say that in this case, you had to use the secondary IP address as a workaround due to the lack of ports in your Router.
I hope this helps.
Best Regards.
I hope this helps.
Best Regards.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
One common usage is when you want to migrate hosts from one subnet to another, such as changing the subnet's size.
BTW, by default, Cisco secondaries hosts will not be able to obtain a DHCP IP.
