Secure Layer-2 extension over Internet
Claudio Battan
I try to repost here one of my posts that found little response ...
I need to extend some VLANs between two location (the Enterprise DataCenter and a remote DR DataCenter).
The obvious solution is using OTV between two CSR1000v's.
The connection I have to use is the Internet, so the join-interfaces will be directly on the public network.
Question: is OTV traffic somehow "protected"?
Can I implement two IPSEC tunnels between the two CSRs and then pass the OTV traffic through this tunnel?
Is there any configuration example?
Thank you
Claudio
as far as I recall. the CSR100v runs on the same code as the AS1000, so yes, you can add IPSec encryption to the OTV. Below is an example:
https://www.cisco.com/c/en/us/support/docs/routers/asr-1006-router/212826-configure-asr1000-encryption-over-otv-un.html
