securing static NAT
jasonww04
How do I make sure that only one public address can use a one-to-one static NAT?
I want to make sure that only 63.xx.xx.0 block can reach my two servers.
Will this work?
ip nat inside source static 172.18.75.12 65.xx.xx.2 route-map trusted
ip nat inside source static 172.18.75.13 65.xx.xx.3 route-map trusted
ip access-list extended secure
permit ip host 172.18.75.12 63.xx.xx.0 0.0.0.255
permit ip host 172.18.75.13 63.xx.xx.0 0.0.0.255
route-map trusted permit 10
match ip address secure
Jon Marshall
Jason
I think you may need to change the acl to
permit ip host 65.x.x.2 63.xx.xx.0 0.0.0.255
permit ip host 65.x.x.3 63.xx.xx.0 0.0.0.255
But i would say that NAT is not really used in this way. Far better to just setup the static NAT without a route-map and then tie down access with an acl on the interface.
Jon
I'll give it a shot. If it doesn't work then I will have to put the ACL on the interface.
So NAT with route map doesn't do what I want.
Now I have to figure out how to construct the ACL, which interface to put it on and which direction it needs to check traffic.
Any ideas?
