Security ?
Jeromy Polachak
Im reading that lets say we have a network with 3 routers. I have the same Line Con 0 password as an example is vodka but i do the service password-encryption command. If i would copy that password down encrypted from the show run command, and try to log in to the line con 0 initial password and type in the encrypted password, that would actually go through without knowing vodka was the actual password? Just curious on this one I seem to not able to sleep anymore cause i just want to learn learn learn.
Jeromy
Raju Sekharan
No. You need to give the actual password to login
Raju
Pius Nolih
I just tried now and it would not go through
