Segment Routing ECMP on IOS XRv 6.1.3 not working
Hi All,
Hope you have a good day.
I'm testing Segment Routing in Eve-NG using IOS XRv 6.1.3.
I'm trying to test the ECMP-aware shortest path on the same metric to the destination and it doesn't work. If there are two paths to choose, it only chooses one.
Do I need to configure to get ECMP or in-built?
Thanks in advance.
pigallo
@htainlynnaung199694856 wrote:
Hi All,
Thanks in advance.
Hello.
SR is natively ready for ECMP so you don't need to configure anything to benefit from the feature.
I'm not 100% sure though if  IOS-XRv fully supports SR features. You should try to test it under XRv9000 vm at least, if you have no real hardware available.
Best regards,
