07-17-2011 05:07 AM - edited 03-04-2019 01:00 PM
Dear expert
I study the BGP behaviour from the cisco document as below.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf1
I have one question about the section "Verification of Inbound Traffic from AS 10 to AS 11", below please find the result of "show" command.
===== result output ===
R103# show ip bgp
BGP table version is 4, local router ID is 10.10.34.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 10.10.34.0/24 0.0.0.0 0 32768 i
*> 192.168.11.0 10.10.13.1 0 0 11 i
!--- The next hop is R101.
* 192.168.12.0 10.10.13.1 0 0 11 11 11 11 i
*>i 10.10.34.4 0 100 0 11 i
!--- The next hop is R104.
R103# show ip route
!--- Output suppressed.
Gateway of last resort is not set
B 192.168.12.0/24 [200/0] via 10.10.34.4, 00:04:46
B 192.168.11.0/24 [20/0] via 10.10.13.1, 00:04:46
======== end ========
The question is that why the next hop 10.10.34.4 to be selected (it should be ibgp, the AD is 200); the next hop 10.10.13.1 not to be selected (it should be ebgp, the AD is 20 but longer as path only). Please advice.
rdgs
Solved! Go to Solution.
07-17-2011 05:38 AM
BGP has a long length decistion to select best path to be installed in RIB. In regarding your question,R3 should think of selecting 192.168.12.0 network as follow:
1. R3 can reach the next-hop 10.10.13.1 and 10.10.34.4. Sure it's all connected network.
2. R3 compares a highest weight value for both paths. Well they are 0 so it's a tie.
3. R3 compares a highest local preference value for both paths. Well they are 100. so it a tie
4. Route originated by local router? no 192.168.12.0/24 is not originated by R3. Can't use this as a condition
5. R3 compares a shortest AS path. R3 routes 192.168.12.0/24 via R4 AS-Path =1 and via R1 AS-Path =4. So R4 wins.
You can check values associated with the prefix by using "show ip bgp 192.168.12.0 255.255.255.0" on R3 and compare it.
Comparing iBGP and EBGP is a condition as well but not a first condition.
Just check out this link: http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
HTH,
Toshi
07-17-2011 05:38 AM
HTH,
Toshi
