Selective NAT
lcaruso
Level 10
Level 10
On an 887VA running 15.x IOS, is there a way to support both public and private addresses on inside vlans? The outside interface is public static ip, so the requirement would be to not nat anything if coming from inside vlan10 but nat if coming from inside vlan20.
I didn't think this was possible since the outside interface would have to use an outside nat command that would not be ignored for traffic coming from vlan10.
Maybe there's a trick that supports both needs?
Thanks.
Raju Sekharan
When you configure nat you can specify in the access-list which range of inside IP addresses you want to NAT. NAt will process only those, rest of the source IPs gets routed without NAT
ip nat inside source list interface overload
Raju Sekharan
stephen.stack
Level 9
Level 9
So you want to host a public IP address inside your router?  Well, sure it's possible, and it's as easy as adding a static route tothe 887. If NAT is setup correctly, you will only NAT IP addresses with source IP of your internal LAN address space.
So, if you add a static route on your 887 to an internal IP address, where this Public IP is to be configured, then when traffic is originated (sourced) from this public 'internal' IP, it will never NAT, and it will just route becuase it will not hit any NAT ACL etc.. The oppostie is also true for inbound traffic
Can send on some sample config, but let me know if this is what you are aiming for?
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
I think the previous post explains it, but thanks just as well for your post.
Did you write Rconfig? Looks interesting.
Thanks.
agreed, much more straight forward than my explanation
Yup, rConfig is all mine, over a year in the making. Sign up for the release - Dec 14th. Hoping to blow some of those over priced config management tools out of the water
