Send multicast stream
interfacedy
Hi Can we use a PC like win8 or 10 or windows server as a video resource to send multicast stream? Thanks
3 Accepted Solutions
Hello
Yes you can, VLC would be aplicable
Kind Regards
Paul
Harold Ritter
Hi @interfacedy ,
VLC can be used as a multicast streaming client and/or server.
Hi @interfacedy ,
Yes VLC can be configured to receive multicast traffic via IGMP. Streaming is often used to refer to video traffic.
6 Replies 6
Hello
Kind Regards
Paul
Harold Ritter
Hi @interfacedy ,
interfacedy
Thanks for your reply.
@Harold Ritter Why VLC can be used as multicast straming client/or server? Its becasue it can produce something like igmp?
One more question: why we call it as steaming instead of traffic?
Hi @interfacedy ,
interfacedy
Thanks!
Joseph W. Doherty
BTW, traditionally, any host can send multicast.  Literally, all a hosts needs to do is transmit the multicast.
Keeping multicast from "flooding" all the same L2 domain switch links, and/or, routing it between L3 networks, can be considerable more involved.  Again, though, a multicast sending host, might not need to do anything beyond transmitting its multicast packets.
Hosts desiring to receive a multicast stream, also, is more involved.
