serial interface speed
ohassairi
Level 5
Level 5
hello
TFGen is a traffic generator
i am trying to test it in GNS3 with a LL connections between 2 routers.
the traffic is continuous and constant. the destination address is the remote router LAN interface.
my problem is: when generating a traffic with 64Kbps for example:
-in show interface f0/0 on local router it shows
R1#sho int f0/0 | inc rate
  Queueing strategy: fifo
  30 second input rate 63000 bits/sec, 65 packets/sec
  30 second output rate 2000 bits/sec, 3 packets/sec
that's ok. but
- in show interface s1/0 on local router it shows
R1#sho int s1/0 | inc rate
  Queueing strategy: weighted fair
  30 second input rate 1000 bits/sec, 2 packets/sec
  30 second output rate 58000 bits/sec, 64 packets/sec
why  serial interface speed is < Lan interface speed ? shouldn't be the same?
thanks for your help
Giuseppe Larosa
Hello Ohassairi,
serial interface has a different encapsulation like HDLC or PPP. LAN interface uses Ethernet II framing.
.Router interface speed is an OSI Layer2 information not OSI Layer3.
For LAN interfaces with no vlan tagging the overhead is 14 bytes because the 4 byte FCS is not counted
For serial interface the overhead is less 4-5 bytes with 2 bytes CRC not taken in account.
To be correct we should say that in LAN interfaces also the inter frame gap ( silence between two frames) plays a role..
However, for router interface counters the different encapsulation overhead is enough to explain the differences.
As a result of this the traffic speed in bit per second is less on the serial interface even if the packet rate pps is the same
What you see is normal
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ohassairi,
Hope to help
Giuseppe
thanks for your reply
i understand that L2 header is different from LAN to WAN but at least we should have the same packet rate.
however in LAN we send :  65 packets/sec and in WAN only 64 packets/sec
i think there is one missing packet. but there is no drops in sho interface !
