Server Reset Connection
ket14pril14
Visitor
Hi everybody!
As a new user of packet tracer, I have faced an issue I cannot fix for couple days. I am working with the following topology:
My goal is to make all the servers(HTTP servers) accessible from all the PCs. Moreover, I need to be able to access Server1 via public address of the Router1. I can achieve this using PAT(NAT overload), if I understood correctly.
I used the following inputs so as to achieve this:
Router1:
Router2:
I managed to ping Server1(192.168.35.2) and successfully recieve reply from the public address 129.55.18.1:
However, I failed to access 129.55.18.1 from the PC2's web browser:
Is there a way to fix this issue?
Martin L
for this to work u need static NAT; try something like on R1
ip nat inside source static tcp 192.168.35.2 80 129.55.18.1 80
Regards, ML
**Please Rate All Helpful Responses **
Mark Elsen
              - FYI : Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Martin L
Regards, ML
thank so very much!
