service-module T1 question
alamile88
Help !
The following configurations were applied to a cisco 2621XM with a T1 WIC module with a point-to-point to a cisco 7613...
The only configurations avalable are the ones from the 2621 router....
interface Serial0/0
description *** T1 Link ***
bandwidth 1544
ip address 10.11.1.18 255.255.255.252
ip ospf network point-to-point
no ip mroute-cache
load-interval 30
no fair-queue
service-module t1 clock source internal
service-module t1 timeslots 24
service-module t1 fdl ansi
The interface was up up. I then realized that there was only one timeslot entered (24) and not the normal range (1-24). Once I made the correct change in the configuration, the interface went up down.
I also tried the "full" option with ESF and B8ZS, and still the interface remained up down. The Telco informed me that I was to do clock source internal.
I tried everything, including just entering timeslot "1" and still, the interface was up down, but when I modified the single time slot to 24 alone, it came back up up.
Any suggestions???
thisisshanky
Level 11
Level 11
Is this a point-to-point between two of your routers ? If then one end shud be clock source line and other end clock source internal. If this is a 24 channel (full t1) then you should specify 1-24. have you done any loopback tests and have the telco run a test to them ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
s.vyas
can post the out put of sh service-module s0/0 pls
