service-policy is removed when changing encapsulation type
gchabannas
one of my customer encounters a problem with a 7606 in version c6sup22-jk2sv-mz.121-26.E4.bin.
When he changes the encapsulation ( ppp to hdlc or hdlc to ppp ) on his serial interface the service-policy configuration is removed.
Exemple :
xxxx02#sh run int ser 2/1/1
Building configuration...
Current configuration : 223 bytes
interface Serial2/1/1
description PAR-DRS_LON_FT
ip address X.X.7.1 255.255.255.252
encapsulation ppp
load-interval 30
dsu bandwidth 44210
framing c-bit
cablelength 10
service-policy output London_policy
end
xxxx02#
xxxx02#conf t
Enter configuration commands, one per line. End with CNTL/Z.
xxxx02(config)#int ser 2/1/1
xxxx02(config-if)#no encapsulation ppp
xxxx02(config-if)#
xxxx02#
Current configuration : 167 bytes
load-interval 30
dsu bandwidth 44210
framing c-bit
cablelength 10
end
xxxx02#
I didn't find any bug about this.
So , can you tel me if it's normal or not ?
Thanks in advance
Gregory Chabannas
pkhatri
Level 11
Level 11
Hi Gregory,
I beleive that is quite normal. Changing encapsulation type on an interface is a major re-configuration and you have to accept such behaviour.
Hope that helps - pls rate the post if it does.
Paresh
