Interesting Policy Based Routing Question
lee
I have a site with three distinct departments that need to traverse two different PVCs on the same choked DS3. They teminate at a 3745 with 4 ethernet interfaces, dept. A (WIRE) uses f0/0 and f0/1 (one for backup) dept B (BRANCH) and C (IMAGE) use f1/0. A DSL backup is there on f3/0 for WIRE and BRANCH to use in case of DS3 failure - dept C CANNOT use this DSL. If the DS3 fails, IMAGE is gone, no worries.
BRANCH/WIRE use PVC 1/500. IMAGE traffic uses PVC 1/501.
How do I policy route this so niether IMAGE, nor BRACH traffic will use the other PVC in case of failure. Also, if the DS3 fails, I need to only route BRANCH/WIRE out the DSL backup. Here is my current config. I have not included any config for DSL backup yet. Also, there is a route-map on the
interface FastEthernet0/0
description connection to Wire_pri
ip address 10.4.22.1 255.255.255.252
ip policy route-map NACHI_WORM_WIRE_USE_PVC500
speed 100
full-duplex
interface FastEthernet0/1
description local lan
ip address 10.4.208.1 255.255.248.0 secondary
ip address 10.48.40.1 255.255.248.0
ip helper-address 10.1.100.39
ip helper-address 10.48.40.1
speed 100
full-duplex
interface FastEthernet1/0
description connection to Wire_bck
ip address 10.4.22.5 255.255.255.252
no ip unreachables
ip pim sparse-dense-mode
ip multicast boundary 94
load-interval 30
speed 100
full-duplex
interface FastEthernet3/0
description DSL L3 Interface, Circuit ID:
ip address 65.233.92.37 255.255.255.0
ip access-group vpn_only in
ip route-cache policy
ip policy route-map nachi-worm
speed 100
full-duplex
crypto map vpnmap
ip access-list extended
BRANCH_ROUTEMAP_ACL
permit ip 10.4.208.0 0.0.7.255 any
permit ip 10.48.40.0 0.0.7.255 any
ip access-list extended IMAGE_ROUTEMAP_ACL
permit ip 10.4.24.0 0.0.0.255 any
ip access-list extended WIRE_ROUTEMAP_ACL
permit ip any any
access-list 150 permit icmp any any echo
access-list 150 permit icmp any any echo-reply
route-map BRANCH_IMAGE_PRB permit 10
match ip address BRANCH_ROUTEMAP_ACL
set ip next-hop 10.25.0.14
route-map BRANCH_IMAGE_PRB permit 20
match ip address IMAGE_ROUTEMAP_ACL
set interface Null0
set ip next-hop 10.26.0.5
route-map nachi-worm permit 10
match ip address 150
match length 92 92
set interface Null0
route-map NACHI_WORM_WIRE_USE_PVC500 permit 10
match length 92 92
set interface Null0
route-map NACHI_WORM_WIRE_USE_PVC500 permit 20
match ip address WIRE_ROUTEMAP_ACL
set interface Null0
Any help is hugely appreciated.
b.speltz
Level 4
Level 4
In addition to these configurations sent, can you also send me the network topology and the configuartions in WIRE and BRANCH departments?. Thus, it will be easy for me to specify the exact policy routing details.
i agree with u.. send topology and connectively diagram, then its posible to give ur solution.
