06-14-2016 11:35 PM - edited 03-05-2019 04:14 AM
What is the difference between set ip default next-hop and set ip default global next-hop ?
Solved! Go to Solution.
06-15-2016 08:19 AM
The set ip default next-hop is the normal command to use when configuring PBR when you are not using VRF. set ip default global next-hop is used to configure PBR when you are using VRF and want to route to the global routing table. See this link for more detail
http://www.cisco.com/c/en/us/td/docs/ios/mpls/configuration/guide/12_2sy/mp_12_2sy_book/mp_mltvrf_slct_pbr.html#wp1101286
Rick
06-15-2016 08:19 AM
Rick
06-20-2016 02:25 AM
Thank you Richard.
06-20-2016 10:35 AM
You are welcome. I am glad that my explanation was helpful. Thank you for using the rating system to mark this question as answered. This will help other readers in the forum to identify discussions which have helpful information.
Rick
