Set Router to ignore startup config
RAW1456
Greetings,
i want to configure a router (ISR 4321) to always ignore the startup config (if one was set) so it always enters Zero Touch Provisioning. Is there a way to do this?
Many thanks in advance!
luis_cordova
Hi @RAW1456
Try this:
(config)# config-register 0x142
The default registre is 0x2102, in case you want to return the router to its normal state.
(config)# config-register 0x2102
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html#pgfId-1056780
luis_cordova
Hi @RAW1456
Try this:
