Setting BGP Local Preference
r.gasper
Hello All,
Wonder if anyone can help? I have a WAN CE router running ebgp to a provider MPLS network PE router. The CE router is runnng iBGP to a core switch. The core switch also has point to point links to a DC( running ebgp), which has a connection to a provider MPLS. I am trying to manipulate the routing so DC traffic goes over the point to point link, and traffic to other remote sites goes via the MPLS WAN.
I noticed that the point to point link to the DC was being used for WAN bound traffic, rather than the local WAN link being used. I tried to set a local preference of 200 from the CE router to the core switch. This sort of worked, however now all traffic goes via the WAN, including traffic to the DC (which should use the point to point link). I then tried using an access-list to deny the DC networks. The access-list was used as a match in a route map, with the set being to set an LP of 200, and applied the routemap outbound towards the core switch. I was hoping the this would apply the LP to all networks, apart from the DC networks that were denied in the access-list. It didn't work!... it appeared to block the advertisement of the DC network from the CE to Core switch.
Can anyone give me any insight as to how I can selectivly not apply local pref to certain networks?
Thanks in advance
IMHO, you need an ACL which permits your DC subnets then.
Create a route-map with two entries:
The first entry just matching the ACL but not setting anything.
The second entry not matching anything but setting local preference to 200.
So after applying the route-map outbound, the DC prefixes will be advertised with the default LP=100 and all other prefixes will be advertised with LP=200.
Isn't  that what you want?
Best regards,
Milan
Jon Marshall
Not sure i follow.
You say the DC networks are not beind advertised from the CE to the core switch but isn't that what you want ie. the core switch receives advertisements for the DC over the point to point links so then it would take that path.
Is it that you want the CE to advertise the DC routes so you can use them as backup if the other link fails ? .
In terms of your route map they may be being blocked because of the way you wrote it. Try this -
1) write your acl to only match the non DC networks
2) you need two permit entries in your route map -
a) the first entry will be as it is now but with the modified acl
b) the second will just be a permit statement with no match or set statement
the idea being that anything routes not matched in the first statement are simply allowed through as is.
Jon
Thanks for your reply Jon,
I would like the WAN route to the DC to be available as a backup.
In terms of the ACL, I don't think I could write the ACL with the non DC networks, as there are over 1000 non DC routes. If I recall correctly, I did have the second line of the route map with a permit line.
thanks
Best regards,
Milan
r.gasper
Thanks Milan, your solution works a treat smiley
Thanks again, and thanks Jon for your reply also
