Setting BGP metrics for neighbors
Steven Williams
Level 4
Level 4
Is there a way to mark different networks with different metrics in the same route-map for the same neighbor?
Like if I want to mark 10.10.10.0/24 with metric of 900 but want to mark 20.20.20.0/24 with metric of 100, can I do this in the same route map?
32 Replies 32
PAs are set for symmetric return and using ip hash. I still do not follow your comment on iBGP multi-path is not working.
Obviously an empty statement will be needed if more prefixes have to be filtered. I just showed how you can set different attribute values within a single route-map which was the initial question, but you're right to say that if other prefixes are learned and no need to filter them in anyway, an empty route-map sequence will be needed
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
