setting PPPoE Speed via Policy Map
hi
I have a 3745 router that works as NAS network access server for PPPoE session and DSL clients the client authenticate to radius server VIA AAA protocl
we want to apply for every Authenticated clients a policy map that can mange thier speed we had the radius attribute that manhes this feature however it's still not working
here is a smaple of my configuration
aaa new-model
aaa authentication login default enable
aaa authentication ppp dsl group radius
aaa authorization network dsl group radius
aaa accounting delay-start
aaa accounting update newinfo periodic 1
aaa accounting network dsl start-stop group radius
aaa pod server auth-type any server-key 123456
aaa session-id common
class-map match-all test
match any
policy-map test
class test
   police 128000
bba-group pppoe dsl
virtual-template 2
vendor-tag circuit-id service
vendor-tag circuit-id strip
interface Loopback0
ip address 10.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
pppoe enable group dsl
interface FastEthernet0/1
ip address 196.201.245.6 255.255.255.224
ip nat outside
duplex auto
speed auto
interface Virtual-Template2
ip unnumbered FastEthernet0/0
peer default ip address pool dsl
ppp authentication chap pap dsl
ppp authorization dsl
ppp accounting dsl
ip local pool dsl 192.168.12.5 192.168.12.20
radius-server host 192.168.12.22 auth-port 1812 acct-port 1813 key 123456
radius-server vsa send accounting
and that's my radius attribute
ip:sub-policy-In=test
Type Reply
thanks in adavance and nest regards
any help
