Setting queueing strategy
lear.jeff
How do I set the queueing strategy on an atm circuit? The router is a 7206 with a pa-a3-t3 and IOS Version 12.2(2)T. Here's the sh int - notice the Queueing strategy: None.
ATM3/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 40704 Kbit, DLY 190 usec,
reliability 255/255, txload 10/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4096 maximum active VCs, 248 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:39:54
5 minute input rate 105000 bits/sec, 69 packets/sec
5 minute output rate 1621000 bits/sec, 351 packets/sec
238861 packets input, 43540009 bytes, 0 no buffer
Received 1354 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
940668 packets output, 539476275 bytes, 0 underruns
thanks,
Jeff
Hello Jeff,
under the interface configuration, do you have the option to set Weighted Fair Queueing for the entire interface ?
7206(config)#interface atm3/0
7206(config-if)#fair-queue ?
If that is not an option, you can configure per VC queueing, where you assign the queueing strategy to the default class, see the configuration example below:
Configuring Per-VC Queueing and IP to ATM CoS on the PA-A3 and FlexWAN
http://www.cisco.com/warp/public/121/flexwan_22821.html
HTH,
GP
