Setting up multi-protocol
dyep110581
Hi There,
I just like to as if its possible to configure to a router 2 protocols like BGP on WAN and EIGRP on LAN side.
Can I also ask for a sample configuration of it to see how its being set or configured on any typical router
Dyep.
Jon Marshall
Dyep
Yes you can run 2 routing protocols on the same router and with BGP this is a common configuration. You would configure the protcols as you would normally eg.
router eigrp 1
network 192.168.24.0
network 192.168.25.0
no auto-summary
router bgp 63251
neighbor 62.7.19.1 remote-as 2845
network 192.168.24.0 mask 255.255.255.0
The above would work fine on a single router. The key decision to make is whether to redistribute EIGRP into BGP and redistribute BGP into EIGRP. The above example doesn't do that but there is nothing stopping you redistributing one protocol into another.
Jon
Jon Marshall
Dyep
router eigrp 1
no auto-summary
router bgp 63251
Jon
Thanks Jon
