Setting up Pseudowire on Cisco ASR 1001-X, not supported
Prodigy
I need help from anyone who knows about setting up pseudowire on ASR 1001-X. I am trying to set up L2TPv3 on an ASR 1001X, the syntax to create this is not working on the ASR running image asr1001x-universalk9.03.16.02.S.155-3.S2-ext.SPA.bi
See Synatx am trying to use below and the XE does not support these syntax:
l2tp-class PE1CLASS
digest secret 0 CLASS
Pseudowire-class PE1LAB
encapsulation l2tpv3
protocol l2tpv3 PE1CLASS
ip local interface loopback 0
The interface does not support the x-connect
Also i tried setting up VPLS but still the syntax is not supported on the ASR 1001-XE
l2vpn vfi context PE
vpn id 100
neighbour 10.2.2.2 encapsulation mpls
Has anyone tried setting up Pseudo-wire on the ASR-1001X
I checked the feature navigator and the documentation. In the.3.16.0S release, the only one that supports the features you are after is in the release below:
asr1001x-universalk9.03.16.00.S.155-3.S-ext.SPA.bin
IP Base/Advanced IP Services/Advanced Enterprise Services
You might want to try and install that release, here is the link to the download page:
https://software.cisco.com/download/release.html?mdfid=284932298&softwareid=282046477&release=Denali-16.3.5&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Thanks for your time and response Georg. As per your response, see the version am running on the ASR, isn't this higher than the one just recommended? Kindly clarify please:
System image file is "bootflash:/asr1001x-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin"
