Setting up Subnet Masks and IP Addresses
MotoMatt5040
Most devices can ping to each other, however there is an issue between e2-47 and es-2 where communication gets dropped. I'm not sure what steps to take to trouble shoot this. I've verified that i configured all the ip addresses i put in he table correctly as well as the subnet masks, my only thought it that im just not understanding the fundamentals of this somewhere.
Martin L
I think PC is on wrong IP subnet.  Router Gig0/1 with 172.19.67.1,  Sw ES-2 has IP of 172.19.67.2, those 2 are on 172.19.67.0/27 while PC has IP of 172.19.67.62, d.g. of 172.19.67.33 which is wrong subnet (172.19.67.32/27 is on Router g0/0 interface).  Fix is very easy in this case.
Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
Hello
Would be easier for you to post the PT file if applicable?
Kind Regards
Paul
This one? the .pka? Im fairly new to this.
Martin L
Regards, ML
Oh my gosh i had used the wrong information for that PC, what a simple mistake...Thank you so much for looking at that for me! i had spent HOURS glossing over it.
Since Project Completion rate went down and router IPs are not correct, I think e2-47 IP and d.g. was correct but the other guy is not.   Looks like your East router Interface IPs must be switched around and you will have to re-do East side switch and host IPs.
Use Check Results and then view Assessment Items for things marked incorrect.
Good luck and have fun!
Regards, ML
