Is IPv6 MLD snooping performed by IOS switches over solicited-node multicast addresses ?
computerone1
The NDP protocol makes use of the solicited-node multicast address.
A host joins its own solicited-node multicast address group both localy (netsh int ipv6 show joins) and on the layer2 domain (a wireshark trace shows that a host configured with a new IPv6 address sends a MLD message for its solicited-node multicast address).
Yet, a Cisco layer2 switch (S0) with IPv6 MLD snooping enabled, placed in between three hosts PC1,PC2,Server1 and an IPv6 PIMv2 router shows:
. no display of solicited-node multicast groups
. a recorded link-local multicast group (Multicast DNS, FF02::FB)
Doing some experiments shows that:
. IPv6 MLD snooping is functionning OK with regular IPv6 Multicast traffic, with the traffic correctly switched relevant to the multicast joined clients (ie not-flooded)
. solicited-node multicast is not snooped, but flooded instead
So is IPv6 MLD snooping performed by switches over solicited-node multicast address? Or is it flooded by design ?
Thanks for any input :-)
Harold Ritter
According to RFC4451, all link scope (ff02::/16) multicast address should support MLD, except for FF02::1. In principle, MLD should apply to all these multicast groups.
https://www.ietf.org/rfc/rfc4541.txt
RFC4451, section
In IPv6, the data forwarding rules are more straight forward because
   MLD is mandated for addresses with scope 2 (link-scope) or greater.
   The only exception is the address FF02::1 which is the all hosts
   link-scope address for which MLD messages are never sent.  Packets
   with the all hosts link-scope address should be forwarded on all
   ports.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
JCLB
As each host creates at least one multicast sollicited node address, you would end up with enormous MLD tables.
Read this nanog archive https://archive.nanog.org/sites/default/files/tues.general.wheeler.neighbor.12.pdf
