setting up vlans affected communication
johncenashia
i have a simulated network of two branches connected to a internet service provider. i set up and configured vlans in each branch but in doing so the pcs in each branch can no longer access thier web server and the isp web server. tried setting up static routes to help resolve this but it did nothing, have absolutely no clue how to fix this. anyone help?
marce1000
 - FYI : Community group for Packet Tracer project questions
 M.
for the VLANs to work, you need to configure subinterfaces on the router. I have made some changes to your router config (marked in bold), I have also added DHCP pools for each VLAN (for the sake of simplicity). I have also attached the revised file:
Regional-Router#sh run
Building configuration...
Current configuration : 1555 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Regional-Router
ip dhcp pool VLAN_10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.167.1.101
ip dhcp pool VLAN_20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool VLAN_30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
no ip cef
no ipv6 cef
ip name-server 192.167.1.101
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/1
ip address 202.15.32.214 255.255.255.252
ip nat outside
duplex auto
speed auto
interface Ethernet0/0/0
ip address 192.168.14.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.14.100 80 202.15.32.214 80
ip classless
ip route 0.0.0.0 0.0.0.0 202.15.32.213
ip flow-export version 9
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 192.168.30.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
M02@rt37
Hello @johncenashia
Here are some extra informations about sub-interfaces, called Router On a Stick 'ROaS'.
https://www.packettracerlab.com/router-on-a-stick-configuration/
Best regards
