Setting up VPN, technical query (pre sales).
r.makhija
Hello!
I have attached my current network diagram. Now, i want to upgrade my network with a secondary VPN on wireless links. I have made wireless links from site A to site B & site A to site C. & at Site A both links are merged. So that site B can communicate with site C. (link between site B & site C is not feasible)
Now, what about the VPN Appliances?
Can you tell me what devices (VPN Firewall or router) should i use.
Note: Both VPNs should run simontanously to auto switch in case of failure.
andrew.prince
Level 10
Level 10
You should consider DMVPN:-
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftgreips.html
Or running a dynamic routing protocol over GRE tunnels, for auto failover via routing updates.
HTH>
Hi!
thanks buddy.
I have never did it. But, i ll try to do this time.
thank!
np - glad to help.
