03-03-2015 11:49 PM - edited 03-05-2019 12:55 AM
Hi Guys,
I am facing issue while putting the SFP 4 port 10 G module in SUP on cisco 4500.can you please advice if its supported and/or IOS dependency if any
appreciate if anybody can suggest their inputs for the same .
below are the module details and switch detail
Module:SFP-10G-SR
Error while inserting into slot 3 or 4 in SUP :March 4 10:42:56.100 GST: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi3/3: New transceiver (speed 10Gbps) is incompatible with this module
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E
2 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E
3 6 Sup 7L-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7L-E
4 6 Sup 7L-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7L-E
5 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E
6 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E
7 12 1000BaseX (SFP) WS-X4612-SFP-E
Mod Redundancy role Operating mode Redundancy status
3 Standby Supervisor SSO Standby hot
4 Active Supervisor SSO Active
current IOS:cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin
cisco WS-C4507R+E (MPC8572) processor (revision 4) with 2097152K/20480K bytes of memory.
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from Reset by peer
27 Virtual Ethernet interfaces
212 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
03-30-2015 10:43 AM
Has it been fixed?
04-02-2018 01:07 AM
It has not been cleared could you help out ?
