SG350 vlans no Internet Access
jazzcampos
Can someone assist me? SG 350 connected to an rv042, only native clan has internet access.
All Vlans can ping RV042 Router Just VLAN 100 and 200 can’t get internet access.
i have an SG350 with Native Vlan 192.168.1.1
-Vlan 100= 192.168.100.2
-Vlan 200= 172.29.240.2
13 Replies 13
Alan Ng'ethe
Level 3
Level 3
The nature of this problem suggests either and border device that's been configured to translate requests from the ip addresses/network that belong to vlan 1 and/or a switch that does not have ip routing enabled, but this is unlikely because the VLANs can hit the gateway device. But in order to be certain, we would want to see the following information, which would greatly aid in troubleshooting;
1. Are the two vlans that are unable to access the internet a new addition to the switch?
2. Could you paste an output of the switch configuration? You could enable ssh on the switch and pull the config via a show run command.
3. If you have access to the gateway device, paste an output of its nat configuration
Thank you.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
Hello Alan,
Please see running config per your request. I am using an RV042 cisco Dual
WAN router but i dont exactly how to configure the NAT.
Thanks.
config-file-header
JPCCORESW
v2.4.5.71 / RTESLA2.4.5_930_181_144
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 10,100,200
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp pool network JPC-ADMIN
address low 192.168.100.91 high 192.168.100.250 255.255.255.0
default-router 192.168.100.3
dns-server 8.8.8.8
exit
ip dhcp pool network JPC-GUEST
address low 172.29.240.51 high 172.29.243.254 255.255.252.0
lease 0 2
default-router 172.29.240.3
dns-server 192.168.1.1
exit
bonjour interface range vlan 1
hostname JPCCORESW
username cisco password encrypted 8f288262e7de38f011a41fcdaa5d9445f5031e3e
privilege 15
username isadmin password encrypted
8f288262e7de38f011a41fcdaa5d9445f5031e3e privilege 15
ip ssh server
snmp-server location "JPC CORE"
ip name-server 192.168.1.1
interface vlan 1
name JPC-ADMIN
ip address 192.168.100.3 255.255.255.0
no ip address dhcp
interface vlan 10
name "MGMT VLAN"
interface vlan 100
name JPC-GUEST
ip address 172.29.240.3 255.255.252.0
interface vlan 200
name JPC-CAMERAS
ip address 172.30.240.3 255.255.255.0
interface GigabitEthernet1
switchport access vlan 100
switchport trunk native vlan 200
interface GigabitEthernet2
switchport general allowed vlan add 1 tagged
switchport trunk native vlan 100
interface GigabitEthernet3
switchport trunk allowed vlan remove 2-199,201-4094
interface GigabitEthernet4
interface GigabitEthernet5
switchport access vlan 200
interface GigabitEthernet6
interface GigabitEthernet12
switchport trunk allowed vlan remove 2-4094
interface GigabitEthernet24
switchport general pvid 100
interface GigabitEthernet25
switchport mode trunk
interface GigabitEthernet26
ip address 192.168.1.2 255.255.255.0
no switchport
interface GigabitEthernet28
exit
macro auto enabled
macro auto processing type ip_phone disabled
macro auto processing type ip_phone_desktop disabled
macro auto processing type router enabled
ip default-gateway 192.168.1.1
ip route 172.29.240.0 /22 192.168.1.1
ip route 192.168.100.0 /24 192.168.1.1
JPCCORESW#
Hi the NAT would be configured on the router not the SG350 as switches dont support NAT generally
Here is a quick doc with screenshots showing you how to do it on your specific model
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4154-configure-one-to-one-network-address-translation-nat-on-rv32.html
Hi Mark,
I have attached some screenshots. If you could let me know what is wrong
with the config with my NAT config on the RV042.
I have did a ping to 8.8.8.8 from the rv042 and it succeeded, but when
pinging 8.8.8.8 from the SG350 its unsuccessful.
Seems the Attachement didn’t go through.
My Config for the one to one NAT is
Private IP- 192.168.1.2
Public IP- 101.99.128.1
Range 1
As I mentioned.
I’m not sure where I’m going wrong.
Please see attachement and below sg350 config file. set default route
0.0.0.0 0.0.0.0 192.168.1.1(Gateway Router)
JPCCORESW#show running-config
config-file-header
JPCCORESW
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 100,200
exit
ip dhcp server
dns-server 8.8.8.8
exit
lease 0 2
dns-server 8.8.8.8
exit
hostname JPCCORESW
privilege 15
ip ssh server
ip name-server 8.8.8.8
ip domain polling-interval 8
interface vlan 1
name JPC-ADMIN
no ip address dhcp
interface vlan 100
name JPC-GUEST
interface vlan 200
name JPC-CAMERAS
no switchport
exit
macro auto enabled
JPCCORESW#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S 0.0.0.0/0 [1/4] via 192.168.1.1, 00:01:37, gi26
C 172.29.240.0/22 is directly connected, vlan 100
C 172.30.240.0/24 is directly connected, vlan 200
C 192.168.1.0/24 is directly connected, gi26
C 192.168.100.0/24 is directly connected, vlan 1
JPCCORESW#
Test ping from Router to 8.8.8.8 successful
Sorry attachement attached.
Remove trunk from this its a routed port not required
no switchport
Change the ip default-gateway to a layer 3 default as its a multi vlan switch
no ip default-gateway 192.168.1.1
To
ip route 0.0.0.0 0.0.0.0 192.168.1.1
You dont need native vlans these days and there should only be ever 1 on a local network if it is in use , which is it 100 or 200 , if you dont require to specifically have it as native remove it and just use standard trunk links not specifying native
Ports are also set as trunk and access at same time meaning trunk will always take pref , choose 1 , if its just pc connected use switchport access only , its another switch or a device that requires multiple vlans use a trunk config
connect a pc to this port , remove the trunk part , make sure pc gets the correct IP address and test do you have internet access after fixing the above too
Description Test PC
Thanks for the information about your SG350. I am guessing it is more likely that the issue is with the RV042. Can you provide information about it? In particular we would want to see information about whether it has routes for the 2 subnets that are not getting Internet access. Also looking for information about how its address translation is set up.
From a device in the subnets that are not getting Internet access are you able to ping the address of the RV042?
Rick
Rick
Please see attached for config file per your instructions. On this config file it indicates the cli commands that i used. Internet access still unavailable for either VLANS. 1 or 100.
I have also included the routing table again for the RV042.
kindly advise next steps to try.
You have provided the config of the SG350 and the output of show ip route from it. These show clearly that the SG350 is routing for vlans 1 and 100 and is routing them over the routed port Gig26 with the RV042 as the next hop. You have also provided a screenshot of the routing page of the RV042. And clearly it has routes for the subnets of vlan 1 and vlan 100 with the SG350 as the next hop. So it is pretty clear that the problem is not a routing problem.
The other likely cause of symptoms like this is address translation. Can you provide information from the RV042 about what it is doing for address translation? Or can you post the config of the RV042?
Rick
Rick
Internets working from router thats good can you try using a default route on the switch instead of multiple routes and a gateway , ip route 0.0.0.0 0.0.0.0 x.x.x.x (LAN INT on router )
it doesn't look like anything attached ?
In addition to the advice about NAT given by Malone, I want to add the following;
In the device datasheet I can see that the SG350 supports IP routing, but see some routing statements that are not clear in your configuration.
The 172.29.240.0 /22 appears as a directly connected interface (interface vlan 100) on the switch. 192.168.100.0 /24 appears as directly connected on interface vlan 1. Could you elaborate on what device has 192.168.1.1?
If indeed it is the switch (as you say), then those routes are redundant because they are directly connected interfaces. If it is your router, then I would delete those routes and replace them with a default route pointing to the RV.
ip route 0.0.0.0/0 {ip address of the router}
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5724-configure-ipv4-static-routes-settings-on-a-switch-through-th.html
Hope this helps.
