Sg550 - sg550 switch inter vlan routing
Yasmeen
HI Team,
          In My Office we are using cisco sg550 two switches, but i am unable to access inter vlan routing, bith switches has different vlans with different subnets
     we are using 192.168.128.0/20 network under this we are using VLSM concept with 12 vlans assigned, but i am unable to ping diffrent vlan.
below are my two switch configuration, pls check and tel me the needed configuration to complete.
switchf8f915#show running-config
config-file-header
switchf8f915
v2.4.0.91 / RTESLA2.4_930_181_042
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink te
unit-type unit 2 network gi uplink te
unit-type unit 3 network gi uplink te
unit-type unit 4 network gi uplink te
unit-type unit 5 network gi uplink te
unit-type unit 6 network gi uplink te
unit-type unit 7 network gi uplink te
unit-type unit 8 network gi uplink te
unit-type-control-end
vlan database
vlan 2-3
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switchf8f915
interface vlan 1
shutdown
interface vlan 2
name cisco
ip address 192.168.132.2 255.255.254.0
interface vlan 3
name Arris
ip address 192.168.137.130 255.255.255.128
interface GigabitEthernet1/0/1
ip address 192.168.139.66 255.255.255.248
no switchport
interface GigabitEthernet1/0/2
no switchport
interface GigabitEthernet1/0/4
switchport access vlan 4
interface GigabitEthernet1/0/8
switchport access vlan 2
interface GigabitEthernet1/0/9
switchport access vlan 3
interface loopback1
ip address 1.1.1.1 255.255.255.255
exit
ip default-gateway 192.168.139.65
switchf8f915#
second switch:
switchf8fa54#show running-config
config-file-header
switchf8fa54
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 5-6
exit
hostname switchf8fa54
interface vlan 5
ip address 10.1.1.2 255.255.255.0
interface vlan 6
ip address 20.1.1.2 255.255.255.0
ip address 192.168.139.65 255.255.240.0
no switchport
exit
switchf8fa54#
pieterh
sg550 admin guide
25.5 ip routing
To enable IP routing, use the ip routing command in global configuration mode.
To disable IP routing, use the no form of this command.
Syntax
ip routing
