show adjacency int command in cef
sarahr202
Level 5
Level 5
hi every body!
I need some help with the following:
switch# show adjacency fastethernet 6/1
protocol int address
ip f6/1 100.100.100.1(9)
What is"9" in the above line?
00d004823400800
epoch:0
what is epoch in the aboce line?
thanks a lot and have a nice day!
Jon Marshall
Sarah
Have a look at this link - scroll down to the table and all the output is explained. Please come back if you need further clarification.
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094303.shtml#topic1
Jon
5 Replies 5
Jon Marshall
Sarah
Jon
Thanks a lot Jon.marshall!
ullasupendran
Thats the protocol number at which the adjecency is happening.Check this out
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_s1.html#wp1011414
Ullas
Ullas
I'm not sure it does. According to the doc i posted the number in brackets after the IP address is the number of times this adjacency is pointed to by FIB entries.
Jon
hi jon
You document looks correct.I mistook the protocol parameter of command ref in the link i send .
Ullas
