show interface transceive detail on C3650g
j.han
Hi Netpro:
here is my question:
why router prompt me:Diagnostic Monitoring is not implemented.when I use command"sh int trans detail to output optical receive power"
do I need additional configuration if use this command?
version 12.2(50)
Switch#sh int g0/25 transceiver properties
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: auto
Operational Duplex: auto
Operational Auto-MDIX: on
Media Type: 1000BaseZX SFP
Switch#sh int g0/25 transceiver detail
thanks all
Giuseppe Larosa
Hello Jianghui,
Sam has explained the DOM feature in the other thread you opened:
From Sam's post:
Not all modules are DOM capable, see compatibility here:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
So you need to verify if your optical modules support monitoring but you may need also some command in global config mode as explained by Sam.
Hope to help
Giuseppe
Hi Giuseppe:
I checked config and command doc for 12.2.50 version,but I can't find out which command I can config this funcion on cisco3560g,what you mendtioned some command in global config mode is the key.
BTW the SFP is supported by DOM
thanks
Hello Jianghui,
Sam mentioned the following command
transceiver type all
but now I'm not sure it is given in global config and also I'm afraid this platform doesn't support DOM.
I've tried on a C3560E we have and I cannot find any option to give this command it is not present in global config and in interface mode
Hope to help
Giuseppe
Credit to the gentleman who gives credit :-)
