show ip bgp version recent # cli output understanding
fsebera
Level 4
Level 4
Looking for clarification and understanding of the cli command:  show ip bgp version recent #
Example:
show ip bgp sum | i table
BGP table version is 5000, main routing table version is 5000
show ip bgp
Several hundred prefixes are shown
show ip bgp version recent 1
2 prefixes are shown
sh ip bgp < 1-of-the 2-prefixes-from-above >
The table version on this prefix (5000) matches the BGP table version as-well-as main table version
Sh ip bgp < 1-of-the-prefix-found-in-the-several-hundred-prefix-list >
The table version on this prefix is a LOT lower (3442) than the BGP table version as-well-as main table version.
My assumption is the 2 prefixes from the sh ip bgp version recent 1 output are the only prefixes that have been updated since the last table version change.
Frank
indeed. The highest prefix table version is equal to the main BGP table version. If the prefix version for a specific prefix is that much lower than the BGP main table versions, it means that there are probably a lot of prefixes other than that specific one that have been updated.
Does that make sense ? Have a look at the document below for reference:
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/116511-technote-tableversion-00.html
Hi George,
Thank you
Frank
