show log interactive-commands| match (username) vs cisco cli
mohamed hosseny
Simply on juniper  we can find all user command log when type
  show log interactive-commands| match (username).
could you mentione the equivlent command on Cisco asr9k that alraedy running on Cisco IOS XR
Mark Elsen
 - If you talks about Configuration Change Notification and Logging , have a look at this document :
 https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/config-mgmt/configuration/15-sy/config-mgmt-15-sy-book/cm-config-logger.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
mohamed hosseny
No
