QoS DSCP marking
typeonegative
Hey,
I have C3560 and encoutered with such issue, that it doesn't mark packets I want. Configuration:
int vlan 100
service-policy input REDIRECT
class-map match-all HTTP
match access-group name ACL_HTTP
policy-map REDIRECT
class HTTP
  set dscp 63
ip access-list extended ACL_HTTP
permit tcp host 192.168.1.6 any eq www
C3560#show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
I have the same configuration on C3750, everything works. Any ideas?
Donatas.
10 Replies 10
John Blakley
What do you get if you do a "sho policy-map inter vlan 100"?
HTH, John *** Please rate all useful posts ***
C3560#show policy-map interface vlan 100
Vlan100
  Service-policy input: REDIRECT
    Class-map: HTTP (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name ACL_HTTP
    Class-map: class-default (match-any)
      1893 packets, 398571 bytes
      Match: any
        5 minute rate 0 bps
As I see 0 packets, 0 bytes ;-) Maybe here it's a problem.
Is your host 192.168.1.6 in vlan 100?
Yes, ofcourse. I have internet from that host, but I don't understand, why C3560 doesn't catch this packet.
Well, my first thought is to try changing your www traffic to icmp. Ping from the 192 host to something out and see if it marks. If it does, it has to do with the direction that your web traffic is coming from. Is the 192 host a web server? If not, you may never see marking on web traffic inbound.
I tried with access-list 101 permit icmp any any and with no success.
Can you post the interface configuration? "sh run int "
Donatas,
On the ports that you need to have monitored, make sure that you have "mls qos vlan-based" configured on the port. Then you should be able to see packets.
John
Please rate all useful posts...
Hi Donatas,
Could you add also the next entry to your AL and check if it has hits? Please,  check also with policy map if marks packets.
permit tcp host 192.168.1.6 eq www any
Then I would recommend to add the general entry
permit ip host 192.168.1.6 any
and check with policy map if marks packets.
Then, if still does not mark packets I would sugget to apply the service policy to the out direction too.
Hope that helps,
Vasilis
Steve Galarza
Hi All,
New at implementing DSCP. And hoping you can help.
We have moved to softphones and need to start marking DSCP for QoS on L2s. But I keep running into a problem where class-map is being mapped but the class-group does not. I am not sure what I am missing.
here is my config:
config) ip access-list extended VOIP
config-ext-nacl) permit udp any any range 16384 32767
exit
config) ip access-list extended SIP
config-ext-nacl) permit udp any any range 5060 5061
config-ext-nacl) permit tcp any any range 5060 5061
exit
config) class-map match-any VOIP-TRAFFIC
config-cmap) match access-group name VOIP
config-cmap) class-map match-any SIGNALLING
config-cmap) match access-group name SIP
exit
config) policy-map LTU-INGRESS-POLICY
config-pmap) class VOIP-TRAFFIC
config-pmap-c) set dscp ef
config-pmap-c) class SIGNALLING
config-pmap-c) set dscp CS3
exit
int gig1/0/37
service-policy input LTU-INGRESS-POLICY
Here is how I was monitoring the policy-map:
SW-LAB#show policy-map int gig1/0/37
GigabitEthernet1/0/37
Service-policy input: LTU-INGRESS-POLICY
Class-map: VOIP-TRAFFIC (match-any)
12431 packets
Match: access-group name VOIP
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp ef
Class-map: SIGNALING (match-any)
545 packets
Match: access-group name SIP
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp cs3
6399 packets
Match: any
