Show run hangs when clogin to router
bradlesliect
Has anyone across this? How do you Fix? The router has been reloaded already but still does the same. Telnet works fine.
Cisco 2811 Router - c2800nm-ipbase-mz.124-3f.bin.
Is this an IOS bug or is it clogin?
ssoberlik
Level 4
Level 4
This may be due to the IOS version running on the router. The IOS running on the back end will get stuck if it corrupted which inturn may stop or hang the process running on the router.
imclernon
I think this may be due to memory fragmentation. Have a look at the following link
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6f3a.shtml
