Simple BGP MED lab:why traffic does not flow via Edge2?
news2010a
Level 3
Level 3
Hi there, I have reviewed everything possible and I still can't figure out:
I shut down interface from Edge-1 to Primary ISP router. Then from Edge-1 I ping Primary router and I was expecting to see traffic flowing thru Edge-2. That does not work though. I already reviewed route-map and prefix-list and I can't understand what is wrong.
Please find attached diagram and show run for both Edge-1 and Edge-2 routers that I configured.
5 Replies 5
news2010a
Level 3
Level 3
Please ignore previous files. I fixed an issue on the route-map.
Consider these ones here. Issue still persists though.
Hello Marlon,
link between the two edges is in another FR subinterface.
What are you shutting down to emulate the fault?
and also you need to advertise the prefixes for which you want to modify MED check they are advertised on iBGP session
also you should try to ping primary on an ip address different from wan link
Hope to help
Giuseppe
i think i found it a bit strange
if you want to effect your traffic tward primary and back up why you use MED in out direction
this will effect the incoming traffic from primary and back up
for traffic to primary and back up
you couuse lcal prefrence, orign, as path in the inbound direction
The purpose of the exercise is:
There are e-commerce servers (network 65.7.128.0/18) close to Edge-1 router.
For that reason Edge-1 advertises 65.7.128.0/18. Then I want to control incoming
traffic from the ISP destined to those servers by making traffic flow thru Edge-1.
I apply the same concept for the other network 197.1.1.0/24 and advertise it from
Edge-2, so that incoming traffic from ISP should be directed to Edge-2. To my understanding one way to control incoming traffic this way is MED. Let me know if I am missing something.
I will add the advertisement below on Edge-1 and Edge-2 and test it then.
interface Serial0/0.1 point-to-point
description Edge-1 to Edge-2
ip address 172.16.1.6 255.255.255.252
frame-relay interface-dlci 101
interface Serial0/0.2 point-to-point <==== I shutdown this for testing.
description Edge-1 to Primary
ip address 140.1.0.1 255.255.255.252
shutdown
frame-relay interface-dlci 102
router bgp 123
no synchronization
bgp log-neighbor-changes
!include this
network 172.16.1.0 mask 255.255.255.252 <=== including this on advertisement
network 140.1.0.0 mask 255.255.255.252 <====including this on advertisement
network 65.7.128.0 mask 255.255.192.0
neighbor 140.1.0.2 remote-as 145
neighbor 140.1.0.2 route-map SetMED out
neighbor 172.16.0.2 remote-as 123
neighbor 172.16.0.2 update-source Loopback0
no auto-summary
ok in this case you are correct
you can MED, AS path or if you go a bit advanced you can use conditional advertisment
anyway good luck with your learning
