Simple Question: How to cancel out of a bad DNS request?
daeus1234
I thought CTRL Z would quit out of a bad DNS request when you type a command in to iOS that thinks it is a DNS Name, I know you can disable this by typing a command but is there a way to quit out of it, as and when you type this by mistake?
vmiller
Level 7
Level 7
Try ctrl shift upper case 6
johnlloyd_13
Level 9
Level 9
Don't forget to hit 'x'
Ctrl-Shift-6 and X
Thanks John, i thought i missed one small detail.
You can avoid everyting by configuiring no ip domain-lookup.
Thanks CTRL Shift 6 seems to do the trick for cancelling the bad DNS request.
