simple question
Amr Ali
Kindly i need to ask , what does it mean by subnet zero at this phrase " The ip subnet zero command is not configured on a router "
Thanks for help
blau grana
Level 7
Level 7
clear explanation with example.
http://www.packetu.com/2011/11/14/the-ip-subnet-zero-command/
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
6 Replies 6
blau grana
Level 7
Level 7
Best Regards
Steven Clinton
Ultimately it means that you can use a subnet that has a 0 in is network portion, this didn't use to be possible.
I.E 192.168.0.1 /24
Hi Steven,
192.168.0.1/24 is not a good example. From a classful perpective, 192.168.0.1 is a class C with a natural network mask of 255.255.255.0. There is no subnet as such in this case, therefore no possibility for the subnet bits being all zero. It would be a case of subnet-zero if you had 192.168.0.1/25 for instance.
Harold you are correct, I was multitasking at work and intended to put 172.16.0.1 255.255.255.0 as my example.
Amr Ali
Thank you all , for your efforts
Emad.arezoomand
HELLO
i bought a linskey E1200 some days back and i tried to fix it myself , it was my first time to fix a router myself and i want it for my home only . ive fixed the internet cable and the cable from router to my PC and i went trough the steps over the CD provided in the pack . but and the end  of the setup there is an error coming that the router cant connect to internet .
i have asked my isp provider and they took the router to set up the settings and when they brought it back they told that its ok now and it was working with them but ive tired it over my pc and 2 other laptops (direct cable) to connect to internet via router but its not wrking . the cable coming to me is a pppoe and i have a user name pass over it , ive tried also to go to this 192.168.1.1 ip and choose the pppoe and insert my username and pass there but after this my network sahring shows that i have access to internet and at the status i can see it is connected and ip of the network has been stablished but how much ive tried i couldnt brows any page its not loading any page just like to conction is there .
i want to conect my internet to my router to have both internet over my pc wich has no wifi and to have wifi all over my home , would u pls help me to fix this issue ?
regards
